your OEM kit doesn't carry tensioner and idler pulleys.
try these timing kits:
a) rockauto AISIN Part # TKT003 with water pump (no housing) at $122
it also does NOT have the drive belts, nor thermostat or its gasket. It also does not have the oil pump seals/gaskets.
or this:
http://cgi.ebay.com/ebaymotors/Fits-...item2a09d6e2e0
It does not have the oil pump seals/gaskets.
at $184
or go with your kit you found, but pickup tensioner (and spring) and idler pulleys elsewhere (NSK or Koyo brands are OEM on bearings).
as a holder tool I used this from amazon:
$31 free shipping
however you will need your own bolts (also for HB puller, read below), you can get them in Home Depot or Lowes or Ace Hardware, they are hex head bolts M6x1.00 around 50mm long (get 2 pairs), also get matching M6 nuts and M6 washers (wide, like 3/4'' diameter) you will need them for HB puller.
loan those tools for free (refundable deposit required) from Autozone, they will make the job easier:
Harmonic Balancer puller
http://www.autozone.com/autozone/ino...ersSpecialized
OEM27019
1/2'' breaker bar (get a matching 19mm 1/2'' socket for it so can easily loosen the crank bolt with starter blip method)
OEM 27121
Torque wrench 1/2'', so you may need adapters from HFT so 3/8'' sockets fit on it:
http://www.autozone.com/autozone/ino...lvetrainRepair
OEM27043
http://www.harborfreight.com/4-piece...set-67925.html
or pick up your own torque wrenches from HFT
