The K&N direct fit is perfectly legal in all states. What they are saying is modified intakes (without C.A.R.B. certification) may not pass inspection. For example; if you took out the airbox and stuck a K&N cone filter on it, then it's not legal. But if you simply replace the OEM with a drop-in K&N, you're fine.
"Yūko" 2001 Camry 5S-FE/A140E @ 90k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 156k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 2K
Reason: grammar
