Here's my threads it might not be the most concise but there should be most of all the information you need.
1. Make sure you put the service bolt in the cam shaft.
2. Do not reuse the head-bolts i made this mistake was not fun tearing down again after i discovered i was still having overheating/mixing of coolant and oil problems.
Headgasket job how long should it take
Questions on starting camry recently rebuilt.
thread number 2 deals with camshaft placement so that the engine has proper compression while thread number 1 deals with more of the taking apart of the engine. If you have any questions don't hesitate to ask.
