maybe weak fluid/pump pressure,, maybe flush it, if dirty,, clean the screen in the resiviour.... and if that doesn't help, maybe the pump seals are leaking internally in the pump, not supplying enough fluid pressure... a rebuild of the pump or a new pump may help.. nor sure if you can test pressure readings and what they might be..
or maybe the rack itself has a problem in it.. a valve partially clogged, or leaky seal in the rack...
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
