camry won't start, suggestions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2011, 12:01 PM   #1 (permalink)
View crc13's Photo Gallery
1994 v6, went to start it this mornig and as I turned the key, radio went on, chimes on, but nothing with the engine. I turned it and nothing, not even turned over. Battery is new as of 2 months ago. I tried jumping it, nothing. Any suggestions? Any tests I can do to find out what it is?
crc13 is offline   Reply With Quote
Old 03-27-2011, 12:19 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260040
View Yuko's Photo Gallery
It could be a number of things including bad starter, bad connection, or a bad starter relay. I had to fix Camry before that wouldn't start and it turned out that the previous owner installed a kill switch under the dash and the new owner accident kicked.
"Yūko" 2001 Camry 5S-FE/A140E @ 90k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 156k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 2K
Yuko is online now   Reply With Quote
Old 03-27-2011, 10:09 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
probably starter contacts, hit it with a hammer while someone crankig it and see if it helps. if yes then you need a new starter or a rebuild kit.
make sure the battery has clean terminals and is free of any corrosion/oxidation, they should be clean and tight.
Old 03-28-2011, 10:28 AM   #4 (permalink)
Gameroom cash: $303755
^ What fenixus said, but more specifically, tap the solenoid on top of the starter as it sits. It's the contacts inside the solenoid that wear and cause starting problems. If that does start the car, the solenoid contacts can be replaced cheaply without replacing the whole starter. If the car starts after tapping it, read this article on replacing the contacts:
Starter Solenoid Contacts Replacement DIY (2000 I4)
Mike
