1992 camry water pump
Suddenly car sounded like it had a loose marble near the alternator or water pump. Removed alternator belt. The marble noise did not go away.
I put in a new timing belt and water pump. Timing was not a problem because the belt did not break and I never turned over the motor. But I did mark the sprocket with white out. I have replaced the timing belt before. So more of a general pain than difficult.
I guess 238,000 miles ok for a water pump. The bearings were loose,causing the propeller fins to rattle against the housing, I think.
Back to normal now sounds great and runs fine.
