I'm having a tough time diagnosing a squeaking sound that seems to be coming from inside the gas tank of my 97 Camry (4cyl). It started out as an occasional squeak (couple times a day) to a full-on pull your hair out issue
Here's a thread that also describes the same behavior I'm experiencing (I haven't removed the fuel pump to take a peek since it seems there's nothing to see):
what could possibly be scratching the bottom of the fuel tank
Basically I'm hearing something squeaking/scratching metal on metal when traveling at slower speeds. The sound will continue even after stopped...like a pendulum swinging back and forth. I'm thinking that the fuel moving forward and backward is causing something to move inside the tank. This weekend I replaced the rear springs/struts and sway bar bushings, so I know that isn't the problem. I can bang/push on the gas tank underneath the car and replicate the sound as well, so I'm positive the sound is coming from inside the tank. Anyone know what could be going on?
UPDATE
Sounds like a loose baffle inside the tank could be causing this. Read post #5 below
