Replaced alternator - what else?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2011, 07:12 AM   #1 (permalink)
View GaspipeBob216's Photo Gallery
Ok, have a 99 Solara 4 cyl. Battery light came on inside the vehicle and the wipers were moving really slow. I took the battery in for a test - was fine. I then put a multimeter on the battery while the car was on and off -and it read 12V DC the whole time. That lead me to believe it was the alternator - so I replaced it.
It did not do the trick. Same problem, and now the battery is down to about 7 V - so it is not getting a charge at all. Any ideas???
I saw that there are two fuses for the alternator. One was a small 5a labeled 'ALT-S' - I changed it. I saw the other is a 100 amp that would not pull out - I have no clue how to remove it in order to test it.... Has anyone done that before?
Also, I checked continuity between the alternator and positive battery post - that was fine too....
2008 Highander Sport
1999 Solara
1967 Mustang Coupe
GaspipeBob216 is offline   Reply With Quote
Old 03-28-2011, 07:50 AM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
It could be excessive drain with the car off. Check to see if something pulling power even with the key off.
Also, a bad battery could be it. Sometimes cells will conk out and its hard to test. If you have a second car swap batteries and see what happens.
carsrus is offline   Reply With Quote
Old 03-28-2011, 08:20 AM   #3 (permalink)
I tested for drain - that was fine. This issue is that it isn't charging.
Will try swapping batteries. I took this one into Autozone on saturday and it tested fine there, but will see what happens when I swap.
1999 Solara
1967 Mustang Coupe
Old 03-28-2011, 10:16 AM   #4 (permalink)
View AlmightyCamry777's Photo Gallery
It's possible the alternator is bad out of the box. It's happened to me more then once. A brand new $150 autolite alternator, hooked it up and tested with the VOM - bad. so i'd Have that tested also.
AlmightyCamry777 is offline   Reply With Quote
Old 03-30-2011, 07:46 AM   #5 (permalink)
You were right - Turns out alternator was bad out of the box. Great.
I took it up to Autozone to test it and died in the parking lot. They told me there was no way to test an alternator with a dead battery, and offered to call me a tow. At the same time, a neighbor pulled into the lot and I was able to jump and charge the battery to the nearest Marathon.
Diagnosis: Bad alternator.
Have it back home, going to take the alternator back Autozone for a new one. Man....
1999 Solara
1967 Mustang Coupe
