What is causing my FM radio static ?
I just did a tune up on my 1993 Camry LE with the 5SFE engine, installed new plugs, wires, cap and rotor and now I have radio interference on my FM radio. Mine is the distributor version with the coil built into it, under the cap, so there's no coil wire to replace.
I bought AC Delco wires and cap/rotor, and Bosch Plus2 platinum plugs. I've only ever heard good things about the quality of AC Delco parts, so I wasn't worried about them, and the Plus2 Bosch plugs were the exact right part number, with an "r" for "resistance" plugs.
In a nod to all the posts I read for a solution to this problem, I bought a set of NGK wires and just finished installing them, but I STILL have ignition static on the FM radio.
What goes next ? The plugs ?
