Valve adjustment shims 5sfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2011, 08:20 AM   #1 (permalink)
View chcwf's Photo Gallery
Other that Toyota is there any other source buy these shims?
chcwf is offline   Reply With Quote
Old 03-30-2011, 08:44 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
any Machine shop can get them for you
Old 03-30-2011, 02:49 PM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Cylinder Head Supply. I'm not sure, but I think the 5SFE takes 28mm diameter. Better check that though.
BMR is online now   Reply With Quote
Old 03-31-2011, 04:55 PM   #4 (permalink)
I cheated with 7075 Al
N/A Camry Sleeper's Avatar
Gameroom cash: $161600
View N/A Camry Sleeper's Photo Gallery
You can also use the shimless buckets that the 1zz and 2zz Corolla and Celicas share. Instead of having a "wafer" insert that goes into the bucket part of the lifter - it is a one-piece design with a fixed thickness (downside is that you have to exhange the entire lifter if for some reason your valve clearances change which means camshaft removal). These came about in the late 1990s (I believe) as a lightweight alternative to the older design. Weight savings are close to 12g each and work exceedingly well in the high-revving 2zz-GE Celica
Toyota Corolla 1zz and 2zz motors, Toyota Supra 2JZ and the Lexus V8 also use the same exact shims, but I forget if the latter are shimmed or shimless bucket type. I have 20 shimless bucket lifters that I won't need if you are interested - the thicknesses vary on these from 5.100 to somewhere close to 5.4mm each
Let me know if you're interested...
1996 Toyota Camry 5SFE 5-spd 329.9K - UNDER REPAIR
1997 Honda Civic 1.6 5-spd - 183K and 27 MPG average - Dependable DD and *small* family car
1991 Acura Integra 1.8 5-spd - 241K and 28MPG average - I'm game for a simple LS Vtec swap now...
N/A Camry Sleeper is offline   Reply With Quote
