White Smoke out the tail - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2011, 12:35 PM   #1 (permalink)
View ghost111's Photo Gallery
We are working on my friends 2000 I-4 Camry doing rear struts and plugs and wires. But it seems to be blowing some white smoke out the tail pipe. No water in oil or oil in the water. Both are clean. Compression seems OK. What else could produce the white smoke???????????????
ghost111 is offline   Reply With Quote
Old 03-30-2011, 01:17 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
If the white smoke doesn't smell sweet, and your not loosing coolant (Radiator and Overflow are completely full) It's probably just condensation
The Following User Says Thank You to Mister_Perkins For This Useful Post:
coffee-3000 (04-01-2011)
Old 03-30-2011, 01:58 PM   #3 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Probably just some steam burning off.
Just tell him to monitor the oil and coolant level. It could be a slight oil burn, its hard to differentiate between smoke colors sometimes.
carsrus is offline   Reply With Quote
Old 03-30-2011, 04:25 PM   #4 (permalink)
thanks guys. how about that water thingie connected to the throttle body. does that ever leak into the system?
Old 04-01-2011, 02:33 AM   #5 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863210
View BamZipPow's Photo Gallery
Wink
Unless someone's been pounding on the IAC valve...the only way it could leak if someone took it off and sprayed some solvent on the rubber gasket and then tried to reinstall the old gasket and it ends up gitting pinched.
But outside of that...no.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is online now   Reply With Quote
