My Crank pully exploded - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2011, 02:11 AM   #1 (permalink)
View CBZED101's Photo Gallery
So, my battery light came on when I was leaving from a friends house and I figured that I'd either need a new alternator or battery and that I would deal with it in the morning, so I drove home and went to bed. Next morning, went out and popped the hood (figured maybe the old belt just snapped and It'd be a cheaper fix than an alternator or battery) Turns out my crank pulley came separated from itself. So, after $109 at auto-zone I got a new crank pulley and rented a puller and got it popped on with some help from some friends. Has anyone else had this happed? Where the pully / harmonic balancer tear apart from each other? I thought it was a rather odd thing to happen.
Also, now that I've got the new pulley and belt on I have this odd clattering / rattling sound coming from the area, but I cant figure out whats causing it. Any ideas?
NEW on left, OLD on right:
CBZED101 is offline   Reply With Quote
Old 04-01-2011, 04:57 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
i had a pully break the grove for the key bit and the get part of the key caught in it and ware the inner diameter down a 1/4" but this was a 7m and they were prone to that ...... and bhg
^ and leaving it that way!
Old 04-01-2011, 07:59 AM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863210
View BamZipPow's Photo Gallery
It happens with age...mine went on my 22RE on my 1985 Celica convertible. I found it completely separated just like yers.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is online now   Reply With Quote
Old 04-01-2011, 02:07 PM   #4 (permalink)
Well I fixed the rattling sound I had, I just took it to the shop and gave the guy $5 to impact the crank retaining bolt on and that fixed the problem. Also, now with the new balancer / pully I've noticed my car no longer makes the metal on metal clattering sound it used too and the engine is much smoother. The new pully + Gen 4 "dogbone" mount = ultra smooth engine. :-D
Also, I'd like to thank everyone at TN for the advice on using a breaker bar on the ground and tapping the ignition to break loose the crank bolt. That right there made the entire job MUCH easier. Now I'm confident on working on the front of the engine for when I replace my oil pump seal.
