99 Camry Suddenly Cut Out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2011, 04:23 PM   #1 (permalink)
View sabbates's Photo Gallery
I was driving home from work when my 99 Camry suddenly cut out on me.
It turns over, there is spark at the plugs, and I feel pressure pulsations on the fuel line.
Any ideas of what to check?
Thanks a lot.
sabbates is offline   Reply With Quote
Old 04-01-2011, 04:46 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Timing belt.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 04-01-2011, 05:16 PM   #3 (permalink)
csaxon-
I was afraid of that.
Should I just remove the top belt cover and see if the belt is broken?
If it's not broken, could it have skipped a few teeth?
Does the 5sfe engine cause valve damage if the belt breaks?
Thanks
Old 04-01-2011, 06:07 PM   #4 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Originally Posted by sabbates View Post
csaxon-
Thanks
No damage.
Have someone crank while you look at the belt. If its not rotating the water pump probably seized. Either way its a easy job, tons of good DIY's on this site for it. Do the oil seals as well.
carsrus is offline   Reply With Quote
Old 04-01-2011, 06:09 PM   #5 (permalink)
carsrus-
Can the belt be replaced without pulling the engine?
I don't have an engine hoist.
Thanks
Old 04-01-2011, 06:13 PM   #6 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Yup it sure can!
Camry FAQ ------> READ FIRST -----> Comprehensive List of Gen 3/4 INFO and DIY
Old 04-01-2011, 07:07 PM   #7 (permalink)
Thanks for all the help, guys.
If the belt is indeed broken, where can I find a procedure for lining up the new belt with the cam and crank shafts?
All the procedures on timing belt replacements I have seen so far assume the old belt is not broken, so they just mark the positions.
What so you do if the old belt is completely broken?
Thanks
