I recently did my timing belt, water pump, cam seal, crank seal, oil pump seal and oil pump gasket using the DIYs on TN. Like a previous poster said, just use the right tools and follow the steps in the DIY methodically, and you shouldn't have any problems.
The only problem I had was that I put the gear back on the oil pump backwards and didn't notice my mistake until I had it back on the car. I had to take it off and reverse the gear. That cost me 15 minutes or so, but not a real big deal.
My car started and ran fine on the first try after I had it all put back together.
