1993 Camry transmission fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2011, 08:23 PM   #1 (permalink)
View EliTheReal's Photo Gallery
3rd Generation 1993 Camry transmission fluid
I was hoping for anyone here to tell me how i check and/or change my transmission fluid. My car is a 1993 Camry 4cyl. 5 speed manual. I do not see a dip stick to check the level of the oil and im scared that it has never been changed or checked the car has close to 200k miles on it but it still shift and drives pretty good.
I hope this info was enough.
Thanks in advance!!! :-)
EliTheReal is offline   Reply With Quote
Old 04-02-2011, 01:49 AM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
There is no dipstick for the manual. You need to check by removing the fill plug (24mm, facing the radiator). The drain is 17mm under the left halfshaft.
I'd change it 15-30K miles.
The Following 2 Users Say Thank You to JohnGD For This Useful Post:
chronoti (04-02-2011), EliTheReal (04-03-2011)
Old 04-03-2011, 12:30 PM   #3 (permalink)
Thank you man, and what kind of fluid should i use?
Old 04-03-2011, 01:12 PM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Gear Oil.
SAE 90 If your above -18 Degrees Celcius
SAE 75 if your below -18 Degrees Celcius
Recommended oil Grade:
API GL-3, GL-4, GL-5
Capacity
2.7 US Quarts
The Following User Says Thank You to Mister_Perkins For This Useful Post:
Old 04-03-2011, 01:16 PM   #5 (permalink)
Originally Posted by Mister_Perkins View Post
Gear Oil.
Capacity
2.7 US Quarts
Thank you, you guys are some life savers lol :-)
Old 04-03-2011, 01:17 PM   #6 (permalink)
That's what were here for To help each other out!
Old 04-04-2011, 12:59 AM   #7 (permalink)
Or get the 75W90 from the dealer.
Most 75W90 gear oils on the store shelves now have limit slip friction modifiers added already. They are only to be used for non-synchro manual transmissions.
Old 04-04-2011, 06:40 PM   #8 (permalink)
View roach4047's Photo Gallery
Came across this thread while searching. I too have a question regarding a 93 Camry Tranny fluid.
My 93 is a 3.0 V6 auto tranny with 180k miles.
What type of tranny fluid for this tranny?
roach4047 is offline   Reply With Quote
Old 04-04-2011, 08:37 PM   #9 (permalink)
It should have the Aisin A540E automatic transmission, and takes a Dexron-III type ATF.
If the weather turns cold in Ohio, Mobil-1 ATF for the PS steering system, transmission, and the differential would be a good choice. The next would be a synthetic-blend (used to be anyways) Castrol Import Multi-vehicle ATF and Walmart SuperTech Mercon-V (both suitable for D-III, but no longer advertise syn-blend, maybe went to Group II+ from II/III blend? Dunno).
Of course there are boutique ATFs. I tend to stick with common brands. Don't forget to drain/fill the differential. It's often neglected.
Old 04-05-2011, 10:04 AM   #10 (permalink)
View azcat90's Photo Gallery
The 3VZ-FE V6 calls for DEX 2 but that's only because DEX 3 wasn't around yet. Dex 3 replaces Dex 2.
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
azcat90 is offline   Reply With Quote
