Timing belt poor tension when rotated backwards - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2011, 09:10 PM   #1 (permalink)
Location: Houston, Texas, USA, North America, Northern Hemisphere, Earth, Galaxy, Universe, Vergo Supercluster
View oscaryu1's Photo Gallery
I left the bottom tensioner unadjusted, just left it the way it was. Put the new timing belt on, rotated the crank pulley to 0 degrees (matched notch to plastic cover), and reset the camshafts (Dot to dot) and matched the little U groove on the cylinder to the hole in the camshaft pulley...
Question: When I rotate the engine assembly by hand (wrench on crankbolt) forward (pulley rotating clockwise) , with the tensioner properly adjusted, there is no slack at all. When I rotate it in reverse (pulley rotating counterclockwise), the belt gains massive amounts of slack and begins to jump teeth.
Is this normal?!
oscaryu1 is offline   Reply With Quote
Old 04-02-2011, 12:18 AM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
just don't rotate it backwards, as engine in real life never does that
if after aligning you have marks set right (upper tensioner tightened to specs initially in loose position), loosen the tensioner by 1/2 turn on bolt from its torqued down position and rotate the crank almost 2 times, tighten the tensioner to specs when crank points to around 45 BTDC.
set it to zero and rotate 2 more full turns to see if alignment marks are correct and you are done.
Old 04-02-2011, 02:04 PM   #3 (permalink)
kays
