Originally Posted by rusty9
The mechanic said he put in a little less than 2lbs
The from empty charge is about 30oz, so he's probably ok on fill volume, but to do this properly he should have run the A/C to check operating pressures and cold air performance and check for leaks.
and told me there's an electrical problem since the compressor didn't turn on.
Why is not being able to diagnose A/C electrical your responsibility, isn't he an A/C tech?
but are you saying there's no way to properly charge this system without the compressor running?
Well, in a way, if not just to check operating pressures. The initial static fill volume gets you close and may be OK, but does not determine operation and final volume to adjust pressures. An A/C shop should especially be able to do this properly.
If he just dumped all that refrigerant onto one side, would that cause the compressor to lock up?
If he evacuated properly with a vacuum pump, which would also show if the system has leaks, then there's negative pressure (compared to atmospheric) in the system. This allows the initial fill without the compressor running. The system pressure should equalize on both sides of the expansion valve and compressor at this initial fill. He should not have attempted to run the compressor at this fill stage as he's adding pure liquid. The system will not turn on initially anyway due to the pressure switch, but you don't want to start it too fast once the pressure reaches switch on level. It's too much liquid too fast when the compressor's running that will cause seals to blow or possible damage to the compressor. DIY'rs really should not fill A/C with can upside down. If you left the system open for any length of time then moisture gets into it. It's possible rust and lack of initial lubricant has killed your compressor. Adding the correct amount of oil volume is an art after the initial dry fill or when replacing components. The FSM gives oil refill amounts depending on component replaced. Obviously rust floating in the system is not good.
I should add that the 30oz is by volume not weight.
Edit2: Sorry, but another afterthought. R134a operates at higher pressures than R12. The 30oz I gave is for 134a in a R134a system. When filling an R12 system with 134a you'll need less volume to achieve the same operating pressure - even more reason to get the compressor running and care not to overfill. If the pressure switch is a dual high/low switch then maybe your pressure is too high??
