So I poured half a quart of ATF in the engine... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-04-2011, 11:59 AM   #1 (permalink)
Died around age 230, XXX
96ToyoCam164K's Avatar
View 96ToyoCam164K's Photo Gallery
that was about 1,000 miles ago. And it burnt off half a quart of oil on the highway so I'm wondering if this is still something I need to change or can I let it ride until the next oil change?
I was doing it to clean up the lifter a bit...it seems to have done a pretty good job doing so.
96ToyoCam164K is offline   Reply With Quote
Old 04-04-2011, 12:11 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Yeah, Now i Would drain the oil out and get 8 quarts of oil. Put 4 in, run it for a while, drain dispose and put 4 more it.
ATF does a good job of cleaning the motor out, but it doesn't dissolve all the deposits. You can always risk having a piece of carbon break off and clog your pickup, or oil lines.
Flushing it now would be a good idear
The ATF doesn't have the same detergents as the oil, so the lubrication is different. You may see accelerated bearing wear using the ATF
Old 04-04-2011, 12:18 PM   #3 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Agreed. I would have run for about half that mileage with teh ATF in there. But I think you havent damaged anything yet...just drain and fill with maybe some thicker oil to grab anything ATF left loose, then drain and fill with your usual oil.
Chris Crash is offline   Reply With Quote
Old 04-04-2011, 12:25 PM   #4 (permalink)
How long is 'awhile'?
Can I change it out and then wait another 500 miles to do the next oil change?
Or can I drive for about 20 miles and then do the oil change again?
Old 04-04-2011, 12:32 PM   #5 (permalink)
I would use the same rule as seafoam in this case. About 100-200 miles, change again. If you're doing that though you might as well seafoam while you're at it.
Old 04-04-2011, 12:48 PM   #6 (permalink)
Seafoam what though? The throttle body?
Old 04-04-2011, 12:55 PM   #7 (permalink)
Chemist at Chevron
Gameroom cash: $315485
View bdy0003's Photo Gallery
The engine.
95 Camry LE I4 195k
bdy0003 is offline   Reply With Quote
Old 04-04-2011, 01:01 PM   #8 (permalink)
Originally Posted by bdy0003 View Post
The engine.
Ok I still don't get it. You mean spray a bunch of seafoam into where the oil cap is?
Old 04-04-2011, 02:30 PM   #9 (permalink)
No you POUR a bunch of seafoam into the oil.
Old 04-04-2011, 03:09 PM   #10 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 04-04-2011, 03:55 PM   #11 (permalink)
Oh okay. I'm going to try that then...Even with the ATF in there the lifter is still sticking from time to time but not as much as it was beforehand
Old 04-04-2011, 06:09 PM   #12 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Lightbulb
I personnaly would not use cleaning chemicals on high mileage engines,,, if it is high mileage, (say more than 200,000 miles...) you may remove deposits in the piston/ring grooves causing more oil to pass the rings and burn more oil...
once a high mileage engine builds up sludge, it keeps old seals from leaking, fills the gaps in worn grooves...... I am not saying it's good to have, but once it's there removing it can cause unforseen problems... but then again, you may get lucky and it may remove some sludge and not leak or burn any (more oil). If it is a low mileage engine, then it is probably fine to use a cleaner..
IMHO
Despite many cleaners have rave reviews, sludge is still extremely hard to remove by any method except taking apart the engine and placing the parts in the proper cleaning tanks and solutions..
btw, auto trans fluid in the engine (for a very short period of time in a small quantity was/is used for freeing sticky hydraulic lifters..). Which most of these Toyotas don't use..
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
Old 04-04-2011, 07:23 PM   #13 (permalink)
Oh now you tell me LOL. too late I've already put in half a can of that seafoam stuff in there. It was on sale!
I have 221,000 on mine...and I don't think I have a sludge issue. Probably just normal varnish build up.
I went to the mechanic the other day to let him listen to the lifter making noise, and he couldn't hear anything. He said my valves didn't need to be adjusted as valves don't make intermittent noises.
But today as expected, I changed the oil and for some reason the sound is back! I don't get it...it sticks around for a couple hundred miles after I change the oil and then it comes and goes.
It didn't used to sound like that and kind of makes the engine sound like it's falling apart. But lets see if this helps some.
Old 04-04-2011, 07:36 PM   #14 (permalink)
Switch to synth oil and it might stop sticking. And if your engine starts to leak, fix the leak!
