Power Window Issues
Hey all,
My front right passenger window will go down but not up. I've already replaced the switch and the motor/regulator for it as well. If i reverse the polarity on the motor I can get the window to go up by pushing down on the switch, but I cant get the up motion of the switch to work. This is for both the master driver side switch and the front passenger switch. I tested the continuity on the front passenger switch and the power is getting thru the switch when it is pulled up (pins 1 and 5 per my manual).
Anyone seen this before? I'm at a loss of what this could be as I've verified all the equipment is working in one way or another. Could this possibly be an electrical issue from the switch to the motor for the up motion? If so, does anyone know the wiring for that?
