Need help replacing my radio - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2011, 12:33 AM   #1 (permalink)
Died around age 230, XXX
96ToyoCam164K's Avatar
View 96ToyoCam164K's Photo Gallery
I just purchased a new radio today. However, upon taking out my old one I notice it has something attached to it that the new radio does not have. I have attached pictures below, can anyone explain?
I also notice the new radio has 1 black wire in the group of wires that has a metal piece attached to the end of it. I'm wondering what is that for because my old radio does not have that.
When I disconnected my old radio, the 2 connections that are on that one was plugged into 2 connections inside the dash compartment.
The new radio is the one attached to the kit and the old one is the one I pulled out.
Uploaded with ImageShack.us
96ToyoCam164K is offline   Reply With Quote
Old 04-07-2011, 02:08 AM   #2 (permalink)
Chemist at Chevron
Gameroom cash: $315485
View bdy0003's Photo Gallery
K I really don't know what you are talking about.
After reading it a few times, the 1 black wire with the metal piece coming out of it attaches to the antenna connector. The female end should be behind there. If your old radio was an aftermarket, it may have been removed or is still back there. If you google 'car antenna connectors' and look at the images, you'll see what I mean.
Other than that, I can't make head or tails of the rest. You may have an amplifier underneath your passenger seat? You may want to check that out.
95 Camry LE I4 195k
bdy0003 is offline   Reply With Quote
Old 04-07-2011, 12:58 PM   #3 (permalink)
Look at the photo again. Both radios are aftermarket Sony radios. The new one is the Black one the old one is the grey one. The grey one has 2 wires with 2 plugs at the end that connect to 2 plugs inside the dashboard. My new radio does not have that...so Im trying to figure out how do I connect it if my new radio does not have that.
Also, the old radio does not have the Black wire with the metal piece attached to it.
Old 04-07-2011, 02:23 PM   #4 (permalink)
View azcat90's Photo Gallery
Don't know if this helps but Gen 3 Camrys without amplifier (usu. LE) connect with two blue multi-wire connectors and one black antenna wire.
Gen 3 Camrys with amplifier (usu. XLE) connect with one white multi-wire connector, the black antenna wire and the smaller black amp wire.
Check Crutchfield.com if you have aftermarket unit questions...
93 Camry XLE V6
00 4Runner Ltd 4WD
01 Sequoia Ltd 4WD
azcat90 is offline   Reply With Quote
Old 04-07-2011, 04:11 PM   #5 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Crutchfield.com The12Volt.com
'07 Honda Ruckus Big Bore
Old 04-07-2011, 04:18 PM   #6 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Black wire on the new radio should be the ground.
On the one radio, that looks like RCA outputs or for a CD changer.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 05-01-2011, 04:08 AM   #7 (permalink)
OK, I went up to Best Buy and those 2 wires that are missing are actually for sub-woofers. So basically instead of connecting it to those wires, the new radio connects the subs to 2 middle ports.
The sound quality of Sony and Toyota stock speakers is Ah-mazing...
