transmission question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2011, 07:29 PM   #1 (permalink)
View Pkim87's Photo Gallery
hey guys i have a 1997 sedan i4 and i wanna service my transmission. I live in an apartment complex so cannot do the work myself so i will be bringing my car in to the mechanic. i was reading other threads about the differential fluid. do i need to have them change it out also along with the transmission fluid and if i do how many quarts of ATF do i need for both fluids? also i can use any fluid that is Dexron II or III? my understanding is the differential fluid also uses ATF and has a separate plug for it drain. my last questions are does the transmission and differntial drain bolts use the same gaskets or are they two different parts? thanks
Pkim87 is offline   Reply With Quote
Old 04-08-2011, 07:59 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Start by reading through these threads.
DIY: 5S-FE Transmission Fluid & Strainer Replacement Procedure
DIY : Differental Fluid Change
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 04-08-2011, 10:24 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
In the differential use Mobil-1 fully synthetic, or less expensive alternatives like Castrol Import Multivehicle ATF or Walmart SuperTech Mercon-V. I wouldn't go plain dino Dexron III types. So stay with at least Mercon-V.
All these are Dexron II/III suitable. GM no longer licenses the Dexron II/III names BTW. There is only the Dexron VI (6) now, but it's too thin for these older transaxles, IMO.
