Valve Cover Crush Washers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-08-2011, 09:52 PM   #1 (permalink)
View jon1000's Photo Gallery
Does anyone know where I can get the crush washers for a 1MZ-FE? The part numbers would be great too.
jon1000 is offline   Reply With Quote
Old 04-08-2011, 10:13 PM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
The part# W0133-1642612 seems to be sold out everywhere. edit - The Toyota part# is 90902-02001 Google that you'll find what you need. Additional info here.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
The Following User Says Thank You to 71Corolla For This Useful Post:
jon1000 (04-09-2011)
Old 04-08-2011, 11:34 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
^+1
I ordered them from online dealer (TOYOPARTSMAN). Part number for 1mz-fe is: 90902-02001 $1.39/each
If you ordering new bolts too (p/n 90080-10288 $1.23 each LOL ) then they come loaded with washers
Old 04-09-2011, 05:16 PM   #4 (permalink)
redneck engineer
lemegacool's Avatar
Gameroom cash: $233405
View lemegacool's Photo Gallery
cant you just use regular washers? there is a common problem with these bolts snapping off because they bottoms out... the is a fix witch involves removing the crus washers and replacing them with 2 or 3 regular washers... this allow the bolt to be torqued to the right spec without bottoming out and snapping
i'll try to find the post... here ya go! post #5
OEM VS Felpro Valve cover gasket
actually they didnt replace the crush washers but i dont see why you couldnt...
1994 camry v6 5 speed swapped
holset hx35w rebuild/polishing in progress :P
cardomain: http://www.cardomain.com/ride/3872430
lemegacool is offline   Reply With Quote
