ok so my wipers are possessed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2011, 02:27 PM   #1 (permalink)
View rvenom's Photo Gallery
ok so the other week we had a light drizzle and had the wipers set on intermittent and after driving for about a good 15 mins they just stopped on their own. Later after about another 10 mins they just started working again weird. Now yesterday we had a little heavier rain and I turned the wipers on the regular setting and worked fine until the rained slowed down and I turned the setting back to intermittent and they just stopped half way on the windshield and would not work any more, I left the wipers on intermittent and a bit later they just moved back down to where they belong. Now this morning when I turned them on they would wipe the windshield but stop half way only....WTF
So am I alone or should I call a priest to do some prayers over the wipers.
rvenom is offline   Reply With Quote
Old 04-09-2011, 02:41 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
I think it's just the wiper motor going out.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 04-09-2011, 03:22 PM   #3 (permalink)
yeah I just took that whole contraction apart looked ok, lol I took the motor apart too and looked ok brushes had enough life in them and nothing overheated. I called a junk yard in the area the they the motor and transmission for 50 bucks might go check that out monday.
Old 04-09-2011, 10:14 PM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I would make sure the relays and fuses are ok before replacing the motor.
Confirm you have 12V+ to the motor before replacing it too.
Always always always check for voltage, and check fuses / relays before changing a part
Old 04-11-2011, 07:11 PM   #5 (permalink)
ok so doing a quick update, I went to a local junk yard found motor, trans and got new arms also cause mine where stripped and problem fix all for 53 bucks. not bad, thanks everyone for you help
