Camry 98 (V6): Gear Stick stops working (can't change from 'P' to 'D' gear)
Hi all:
I need help from you guys, big big time.
I have a camry 98 (V6), auto transmission, with about 143k mileage. I have owned it since 2008. Just this evening (4 hrs ago), I tried to drive to a local restaurant.
I started the engine, pressed the break, pulled down the hand break, and then switched the gear from 'P' to 'D' position to start driving.
Then I felt some resistance from the gear/transmission stick (I did press the knob on the side whenever I move the stick) and heard some sort of clicking (not exactly but don't know how to describe) sound which was kinda loud (it sounded like some sort of physical connector which connects the stick to the transmission gear box was broken).
Then the stick moves freely without engaging in the transmission gears. So the stick keeps moving but the transmission gear keeps staying in 'P' position.
Please let me know what went wrong in this case. Will it be a big fix for me?
Thanks so much for your insight!
Robert
