I need some paint and body advice for fixing rust damage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2011, 07:29 PM   #1 (permalink)
View mycotopian's Photo Gallery
Help me swap parts into my new doorshell please
************UPDATE****** I went ahead and got a new doorshell and now I need help swapping parts
So I picked up a nice 99 Camry recently. Mechanically the car is solid but the body has seen better days. I would like to use this car develop some paint and body skills. If it all goes south I'll just take the car to get resprayed. I would like to start out with the ugly scare project first.
RUST
I got the molding peeled off today. The clips seem to be merely to hold it straight and are not much of a fastener. I know a new door is technically what I should do but I want to use this as my excuse to learn a little auto paint and body. If I screw it up then I'll go with a new door but for now this is my project. I did a little searching and ordered the following
KBS System Sampler :: GLOSS BLACK :: Stop Rust Paint Kit
This was before I new how bad the rust really was. Now it looks liek I may need to reinforce it from the back with something. Possibly fiberglass.
Here are some pictures of what I am dealing with.
This is right after I peeled the molding off
This is after I pulled away all of the bubbling paint
mycotopian is offline   Reply With Quote
Old 04-12-2011, 07:59 PM   #2 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Yeahhhh, that's NOT repairable. Replace the door.
'07 Honda Ruckus Big Bore
Old 04-12-2011, 08:04 PM   #3 (permalink)
camrtm3's Avatar
Gameroom cash: $102305
View camrtm3's Photo Gallery
You were right right off the start. New Door. BUT if you would like another option what I would recommend is to cut out the rust and a little each because rust is like cancer. If you don't get it all it continues to spread. Then weld in a new piece of metal.
2009 EX-L V6 6Spd MT w/Nav (stock for now)
1996 XLE V6 Camry, KSport GT Pro 9/7, TRD RSB, E153 5spd conversion, Gen 3 front end conversion, OBX Headers, Megan Cat Back, TRD M62 Supercharger
Supercharger whine > ex girlfriends whine
http://www.cardomain.com/ride/3329124
camrtm3 is offline   Reply With Quote
Old 04-12-2011, 08:10 PM   #4 (permalink)
Freakin Scooters
Welding in new metal and shaping it is gonna take SO MUCH more time and money than buying a new door. Plus, if not done correctly, the rust will continue to spread. Seriously though... car-part.com or a junkyard.
Old 04-12-2011, 09:50 PM   #5 (permalink)
Okay well how about until I find a black door for less than $150 what can I do to make this less of an eyesore even if it only lasts a couple months.
Old 04-12-2011, 10:03 PM   #6 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Sand all the bubbled off junk paint off and rust. Go as far as you need to reach health paint and metal. Then hit up home depot and get some primer and black gloss in rattle cans. If you spend enough time it'll look good and last a while.
Theres no other way to really fix that other then sanding and painting. Bondo and fiberglass arent for stuff like that. Bondo on moving parts (doors, tailgates, trunks etc) isnt a good idea as there's a good chance itll just fall off.
carsrus is offline   Reply With Quote
Old 04-12-2011, 11:24 PM   #7 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
There is no way you can fix that properly for less than the price of a decent, used door. Replace it.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 04-12-2011, 11:29 PM   #8 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Wow......looks like a used up skank with hepatitis C and Syphilis. Get that replaced man. Not worth the time and money.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 04-13-2011, 07:57 AM   #9 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
as a temporary fix, use a wire wheel and grind off all of the rust. use bondo to make it smooth and patch the hole. spray paint the area and blend to the rest of the paint.
when i had my old suburban, there was more bondo than sheet metal.
Old 04-13-2011, 08:54 AM   #10 (permalink)
Thanks that is kind of what I am looking for but with a little more detail. Do you have any links on for a step by step process of how to properly do this?
Old 04-13-2011, 12:07 PM   #11 (permalink)
ghettosled's Avatar
its easy to do. i did a quick search on youtube and came across this video which is a basic how to:
you can search for either "bondo" (which is a brand name) or "body filler".
Old 04-13-2011, 08:24 PM   #12 (permalink)
I got lucky and found a black door shell nearby for $100! Now I just have to swap the guts. Are there any good links or documentation I can follow that will help me with this? I'll start a new thread now that I have changed direction.
Old 04-13-2011, 08:31 PM   #13 (permalink)
Help me swap my door components on to the new door please
Well after an overwhelming consensus that my old rusted door was not salvageable I started poking around. This morning I got luck and found a scrap yard with a black door shell in excellent shape for $100.
Now I face the challenge of swapping over ALL of the components such as window, regulator door locks etc. into this new empty shell. Before I dig in I have a few questions.
Is a particular order this should be done in?
Are there any super fragile parts that have to be removed a certain way?
Are there any non reusable parts?
Are there any tricks I should know to make things easier to swapping into the new shell?
Can anybody post or send me some documentation to help me with this?
Thanks guys!
Old 04-13-2011, 09:45 PM   #14 (permalink)
Freakin Scooters
Merging this with your old thread.
Old 04-14-2011, 07:42 AM   #15 (permalink)
View Oceans's Photo Gallery
Found this on the internet as I dont have time to show you but the guy does a good job, and its video format and he has other things as well for repairs to your doors.
Hope it helps you out if the first link doesnt work here is another
http://www.1aauto.com/1A/WindowRegul...mry/1AWRG00155
Oceans is offline   Reply With Quote
