The unit with the housing is much easier to deal with, because you don't have to re-use the old housing, which means removing the old pump and cleaning off the surface. But if you're doing a water pump job, why not just get a timing belt kit and do everything at the same time? This kit has everything you need including the water pump with housing. The only thing it does not come with is the oil pump gasket and seal, which you may or may not need to replace.
edit - that seller shows different shipping prices to Canada for what appears to be the identical kit, this one for example shows shipping at half the cost.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
