Help: Gen 3 Camry warning light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2004, 08:32 PM   #1 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
I'm not that familiar with the warning lights on the dash of the gen 3... but what does the light underneath the Check Engine light mean? It looks like it's for the rear of the car... possibly rear brake light out??
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 05-06-2004, 09:21 PM   #2 (permalink)
All you camry guys around here and none of you know??
91 mr2..07 335i..
Old 05-06-2004, 09:24 PM   #3 (permalink)
View Tarzan's Photo Gallery
Yes thats exactly what it means.
94 Camry Coupe
Tarzan is offline   Reply With Quote
Old 05-06-2004, 09:26 PM   #4 (permalink)
View Camrizzle's Photo Gallery
dont you have an owners manual? if not ill check mine in the morning
1992 Camry LE Auto
1988 Camry Wagon 5 Speed
Camrizzle is offline   Reply With Quote
Old 05-06-2004, 09:29 PM   #5 (permalink)
Just making sure... thanks...
found my answer...
91 mr2..07 335i..
Old 11-27-2009, 11:15 PM   #6 (permalink)
94 Camry
View Eddi3's Photo Gallery
its the orange light right !!
does it come when you push the brake pedal if so it's one of your bulb light out you need to check your bulb or you might have one of your tail light out
hope that helps
Eddi3 is offline   Reply With Quote
Old 11-27-2009, 11:26 PM   #7 (permalink)
View Kenny_McCormic's Photo Gallery
A: Going/gone light
B: Goofylamp failure box
Kenny_McCormic is offline   Reply With Quote
Old 11-28-2009, 02:46 PM   #8 (permalink)
94 Camry
ahhhhh I'm sorry i didn't check the date until i posted the respond
Old 01-14-2010, 10:39 PM   #9 (permalink)
View dutd33's Photo Gallery
Originally Posted by Kenny_McCormic View Post
A: Going/gone light
How do I get rid of it?
Thanks.
dutd33 is offline   Reply With Quote
Old 01-14-2010, 10:45 PM   #10 (permalink)
'95 Tercel DX
silverhawk's Avatar
View silverhawk's Photo Gallery
Originally Posted by dutd33 View Post
How do I get ride of it?
Thanks.
you stand behind the car while someone presses the brake with the head lights on to find out which light it is, then you replace that bulb. simple.
also, check your blinker fluid.
~mike
silverhawk is offline   Reply With Quote
Old 01-14-2010, 11:22 PM   #11 (permalink)
Did that already, sigh. Right now I the tail light warning comes on only while I press on the brake and it goes away when I'm not pressing on it. All of the other lights work fine. Any ideas?
Thanks.
Old 01-14-2010, 11:34 PM   #12 (permalink)
'95 Tercel DX
silverhawk's Avatar
yeah, sorry about bein' a smartass, just tryin' to get a laugh....maybe replace the sensor-box thing? I don't know.
~mike
Old 01-17-2010, 03:59 PM   #13 (permalink)
Does anyone know where this sensor is located?
Thanks.
Old 01-17-2010, 08:11 PM   #14 (permalink)
The sensor box is inside the trunk on the drivers side, its a little white box, VERY expensive to replace. Luckily there is a dirt cheap solution, the box runs the idiot light directly, so all you need to do is cut the wire that runs the idiot light.
TO DISABLE THE LAMP FAILURE IDIOT LIGHT, SIMPLY CUT THE SMALL YELLOW WIRE W/ GREEN TRACER FROM THE LAMP FAILURE BOX.
Old 01-19-2010, 03:21 AM   #15 (permalink)
Originally Posted by JJJJJJ View Post
Dielectric grease on the bulb also works if you keep getting a lamp sensor warning light and the bulb is good.
CRC has a very good one that sells for $5-10, good stuff for all electrical connections.
So you just put this grease into the bulb socket, correct? Sorry for the stupid question.
