is the gen 4 97 camry 2.2L a waste spark system - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2011, 09:34 PM   #1 (permalink)
View beige97camry's Photo Gallery
title says it all. thanks.
beige97camry is offline   Reply With Quote
Old 04-15-2011, 09:38 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
yes
Old 04-16-2011, 06:51 PM   #3 (permalink)
View doodasdad's Photo Gallery
Sorry folks, but I am new to Toyota. Tried the search function with little success...
What is a waste spark system? I have the same 2.2L motor. Thanks
doodasdad is offline   Reply With Quote
Old 04-16-2011, 07:22 PM   #4 (permalink)
type waste spark on google or wikedia and it will explain far better than I can but basically 1 coil for 2 cyl or 1&4 and 2&3 on 2.2 camry gen 4 each have a coil. as 1 fires 4 is down in the cyl but each gets spark thus 4 spark is waste (not used) I think that is the way it is, anyway google to get best explanation.
The Following User Says Thank You to beige97camry For This Useful Post:
doodasdad (04-16-2011)
Old 04-16-2011, 07:38 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Waste spark system is a way to save money. Manufacturers can use 1/2 as many coils but the joke is on the owner. It's like using cheap rubber for the intake valve stem seals to save 50-80 cents each. But at least AFAIK, Toyota moved away from this joke the next gen.
Old 04-16-2011, 07:42 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
and instead they served customers with poor design of cylinder head & bolts in the engine, so every 2az-fe can suffer from head gasket problems ... way to go Toyota
I'd prefer my waste spark story over the HG issues
Old 04-16-2011, 08:07 PM   #7 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
This.
And calling the waste spark system a "joke" is pretty harsh, it works perfectly fine.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 04-16-2011, 10:19 PM   #8 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
I though it was a good thing, 3 coils instead of 6. Much cheaper, and easier to do the rear plugs without coils.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
