Swapped head, idles at 1.8k HOT, drops once in gear?
Recently swapped a new cylinder into the camry (old one was overheated, dropped some valve seatS). Not sure what I'm doing wrong...
After "warming" up the car, everything under the hood seems to be VERY hot. Can hear gurgling around where the coolant temp sensor is. At the "warm" stage, the ECT measures 180 ohms... a bit outside the normal range of "250-300ohms at operating temp". Both fans will eventually come on, and the temperature gauge is always in the middle (normal).
When started COLD, idles at 1.5k, and slowly climbs to a tad below 2k. Accelerates fine, and once in gear it immidiately drops down to 1k RPM, and jumps right back up to 2k in neutral or park. When AC is on, drops to 1.5k everytime.
No CEL, no engine codes (checked).... could it be because I'm using VERY cold spark plugs? (BKR9EIX)? Those were all I had at the time and I just put them in. Started/ran fine... dunno if that would be the problem?
OBTW - Sprayed WD40 all around intake manifold top/back/flange area, no idle fluctuations. Air temperature sensor nozzle is broken off, not sure if that makes a difference (left it hanging in the engine bay... still plugged into harness though).
