Tires, Tires, Tires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2011, 10:51 PM   #1 (permalink)
Gameroom cash: $167900
View capnblinski's Photo Gallery
Tires, Tires, Tires
Folks,
I have an '00 Camry LE w/ the stock wheels with a spec for the tire of P205/65R15, the size presently on the car.
My question is as I am in a snow belt plus drive more on back roads than highway, I am considering using a set of a certain brand's winter-designated tire. Now, the three sizes that the design is available in that most closely match my orignal size
are:
215/60R15
215/65R15
215/70R15
They don't make a P205/65R15.
So, since I want to remain closest in size to the originals, my guess would be the 215/65R15 size.
Whaddya think?
capnblinski is offline   Reply With Quote
Old 04-17-2011, 01:46 AM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
215/60-15 will be the closest to the overall diameter of the orginial tire. The speedo will read the same but the extra bit of wide will help with traction.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 04-17-2011, 02:39 AM   #3 (permalink)
Tom 2000's Avatar
Gameroom cash: $201200
View Tom 2000's Photo Gallery
You don't want wider tires in the winter.
http://www.tirerack.com/winter/tech/...urrentpage=116
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 04-17-2011, 10:50 AM   #4 (permalink)
View Oceans's Photo Gallery
True while wide is good for dry weather traction it hinders you in the snow.
Oceans is offline   Reply With Quote
Old 04-17-2011, 11:08 AM   #5 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Can you not get a 205/60R15?
'07 Honda Ruckus Big Bore
Old 04-17-2011, 01:47 PM   #6 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Yeah, get 215/60-15, 205 is too thin.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 04-17-2011, 05:18 PM   #7 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
215-60's will look a little wider, but should only really be used on rims of 6.5-7" to gain any advantage in summer handling capability. Your original tire size will give you the best results under snow conditions. Do you want to stay out of the ditch in the winter, or hang 9/10th's out in the summer while looking a bit (10mm) cooler to yourself. Todays tires have changed dramatically from the past. Allseason/allweather, tires will get you around just fine in the summer if your ok with mediocer performance, less so in the winter. Summer h/p tires are absolutely useless in snow conditions, and full snow tires, in the summer are like trying to run a half marathon in snow boots. You really should invest in a set of steel rims with 205-65-15" winters, for the snow months, then something else to drive in the summer. This will extend your tire life and safety under both conditions to make it financially worth it if you can.
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is offline   Reply With Quote
Old 04-17-2011, 10:47 PM   #8 (permalink)
Umm.. not on the Winterforce. The idea to run these winter tires year-round came from someone here in sw pa. who is running a pair of 'arctic claws' on a taurus year round - his mechanic recommended to put them on. I started to notice some other cars w/ all four snow tires maybe they got something there- more tread on equals longer life vs.. any harshness/handling snafus - the car itself is not driven too much - only up and down some hilly terrain, a few back-roads and a little highway.And in this case it's all about the economics..
Better to having dedicated winter/summer sets though. If not, the best bet for me is a set of general's 205/65R15's sothe car's tires at original specs.
[/SIZE][/FONT]
[/SIZE][/FONT]
