1994 camry 2.2 auto trans help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2011, 04:39 PM   #1 (permalink)
View tonygk85's Photo Gallery
3rd Generation 1994 camry 2.2 auto trans help!
Have a 1994 Camry 2.2 auto trans that runs great and shifts fine when cold. When car gets to normal operating temp the car does not want to shift into any gear and revs up like its in neutral any ideas??? would like some help on this before i decide to buy a new trans.
tonygk85 is offline   Reply With Quote
Old 04-17-2011, 10:11 PM   #2 (permalink)
can anyone give me some help?????????????
Old 04-17-2011, 10:27 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
when was the last time you drained and refilled it with fresh fluid? how many miles on it?
Old 04-17-2011, 10:59 PM   #4 (permalink)
I change the fluid and filter about 2 years ago and the car has 134,000 miles
Old 04-17-2011, 11:30 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
try draining the oil fluid out and refill with a fresh one, see if it helps it.
fluid on it should be changed every 30k miles under normal operating conditions (e.g. not much city driving) or 15k miles under sever conditions (e.g. lots of city driving).
you may want to drain and refill the differential too if it wasn't done the last time. 2 years, around 24-30k miles ago?
Old 04-18-2011, 10:37 PM   #6 (permalink)
thanks i will give that a try
