power steering pump replacement ?????
Hi, I still have the 95 camry v6 i had a full tuneup done maybe 2-3 weeks ago, car steered fine on the way there, mechanic even drove it before doing work on it, and had no problems with steering. After having plugs , coil boots , pcv valve, air filter, replaced along with having a knock sensor replaced. I pay and start to pull off, but the car is hard to steer. First thing the guy says is Its probably the pump. WEIRD that it decided to go right after i had all that work done. somebody on this board said it might be a vacuum line or vsv i think, When i took car back, mechanic said he didnt see any vacuum lines loose. I wish i knew what else to look for. ( ANY HELP IS WELCOME)
LONG STORY SHORT. I have purchased a new pump, and wanted to know is there anything else i need to purchase for the job, like gasket, seal belt, or any other parts that are commonly replaced when replacing the power steering pump?
