Indirect way to check for engine sludge?
If you change your oil (I've always used Valvoline conventional dino) and filter, and 150 miles later the oil on the dipstick is still crystal clear, do you think that indirectly verifies you have no sludge problem?
You'd think that after 150 miles of operation, if you had sludge, it would have discolored/darkened the oil.
It probably doesn't work the other way around though. In other words, if your oil IS discolored after 150 miles, it doesn't necessarily mean you have a sludge problem. Could be due to something else.
Any thoughts?
