power steering leak - pump or rack? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2011, 09:20 PM   #1 (permalink)
View camryowner25's Photo Gallery
My 1998 Camry is leaking power steering fluid. An independent mechanic says the pump needs to be replaced and my local Toyota dealership says both the rack and pump need to be replaced. I do not know who to believe and do not want to pay another mechanic a diagnostic fee.
How can you tell if the leak is coming from the rack or the pump (or both)? I put some cardboard under my car and the leak appears to be coming from the passenger side. The car steers normally and I have never heard any noises when steering. This leak has been going on for over a year now and is now getting worse. I now have to add fluid to the reservoir once a week. Since I'm not experiencing any noises or issues with steering, which is the most likely source of my leak?
I thought about adding some Lucas Stop Leak to the reservoir but was afraid that it could possibly make things worse. Since I'm not experiencing any noises or problems steering, I don't want to do anything to mess that up. Is there any risk to trying the Stop Leak product?
camryowner25 is offline   Reply With Quote
Old 04-20-2011, 12:09 PM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
aside from saying the leak is by the passenger side, can you narrow this down further? is it leaking from a pressure line? from the pump itself? from a boot on the rack? possibly a leak in the reservoir or the supply/return lines from to the pump.
degrease the area and see where the leak is to know for sure. it could be just a line since there isnt any noise or loss of power steering.
Old 04-20-2011, 04:51 PM   #3 (permalink)
My mechanic degreased the area a year ago and said it was leaking from the pump itself. 9 months later, the Toyota stealership said that it was leaking from the rack when I took it in for an oil change. My mechanic told me that I could damage my rack if I let the reservoir run dry but that has not happened. I do not know if the Toyota guy is correct in his assessment or if he just guessed that it was the rack since it is a common problem with 4th generation Camrys. If the rack needed to be replaced, would I be experiencing any symptoms other than this annoying leak? Is there any risk to trying the Lucas Stop Leak?
Old 04-20-2011, 05:21 PM   #4 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
Lucas PS stop leak is good only if its a minor leak. I have used lucas PS stop leak recently on my camry and it has significantly slowed down the leak.
But I would still say narrow down the leak's origin yourself rather than relying on somebody's assessment. At least you'll have peace of mind.
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
