Jbl amp bypass - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2011, 09:50 AM   #1 (permalink)
View harrison06's Photo Gallery
Jbl amp bypass
My front speakers and tweeters wont work in my 2001 camry. The guys at best buy said the amp is blown (because the back speakers work, and they say the front are hooked up to the amp), so I bought the harness for it (Metra 70-8116) and now I cant figure out how to install it. I want to keep the stock stereo deck, I just want the front speakers to work. Ive looked online all over the place and it seems like no one else has EVER had this problem.
Thanks in advance for any input.
harrison06 is offline   Reply With Quote
Old 04-20-2011, 01:00 PM   #2 (permalink)
View slavie's Photo Gallery
Well, the AMP is located under the glove box (take off the cover above passenger foot area, and you should be able to find it there along with the ECM). I think the easiest fix in your case would be to just buy one of these amps second-hand on eBay for like $30-40 and replace it. EDIT: here's one for $35
Otherwise, I'm not sure if bypassing the amp would work very well, as the non-amp audio systems (like mine) don't have the tweeters in front doors, so you might end-up with your tweeters being not used.
If you do want to proceed with your original plan, just locate the amp, and from there on you gotta make sure you figure out what cables go where.
Hope this helps.
slavie is offline   Reply With Quote
