Hey guys, its a 4 cyl engine 5s-fe.
[SOLUTION]
How to check if your crankshaft is synced with your camshaft
1. Set the camshaft pulley to the v-notch/TDC
2. Set your crankshaft at 0 degree (there should be a small notch on the gear and the plate of the engine)
3. Place a stick in cylinder no.1
4. Rotate the crankshaft by hand and wait till cylinder 1 is at TDC (when the stick is at its highest]
5. Place timing belt on etc.
DONE
! Your crankshaft and camshaft are now in sync
Thank you pmes & JohnGD for your advice and suggestions!
