Originally Posted by tsg234
I have a 1999 Solara with the 3.0 V6, a while ago the check engine light came on with the P0135 (O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) so I put in a bosch O2 sensor with the OE harness. No more than 50 miles later the check engine light is on again, but with a new code P0420 (catalyst system efficiency below threshold bank 1) does anyone have any idea what could be going on here?
it is very possible that the p0420 is caused by your new bosch oxygen sensor
toyota is very picky about that sensor, i've seen most use denso only.
or you let the P0135 stay extended long period of time, and caused damage to the cat.
