There is a small hose on the bottom of the washer tank, attached to the pump. (You have to remove/loosen the plastic splash shields on the corner that the tank is located to see it.) It probably came off.
Mine did on my 96. The first time I just put back where it belonged, pleased that it was an ez fix and not a hole, but it came off again a couple of days later.
The second time I removed the little hose and took to NAPA and bought a fluid resistant replacement piece for 70 cents. Hasn't leaked a drop since.
Good Luck! Hopefully yours will be as cheap and ez to fix as mine was.
