Originally Posted by RichieRichJP
Nothing is better than a BBK brake kit, for the Camry. Its only $1300 or so. This custom shit probably won't outperform it and cost comparably the same.
Well, not really...
As you know I move at a snail's pace on things so time is on my side for beta-testing and such. Although the BBK is a nice option, my goal of making carbon brakes for under $1000 is still working out nicely. Granted, I did pay almost $2000 in tooling cost to make this happen, but when it's done I'll have the ability to make more. So tooling costs aside here's how it goes so far:
10 7/8" carbon rotor - $90 to $125 depending on the vendor (ships from overseas sometimes)
1" X 8" X 8" 7075 T651 aluminum plate for the hat $40
New carbon brake pads $60 to $80 depending on vendor
New SS rotor mounting bolt hardware: $15-$20
Total front BOLT-ON replacement costs: $530
May have to upgrade to DOT 4 or DOT 5 brake fluid for more extreme applications - more on that later. This usually requires new brake lines, calipers, master cylinder, and proportioning valve (I hope not though
The rear brake rotors are actually cheaper than the front but measure 11.875" wide by .750" thick. This may prove to cost a little more to adapt but I'm confident that I can still do it for less than $1K invested
Besides, even if it did cost a little more than what I'd originally anticipated I won't need 17" or larger rims to make a BBK work. I don't know how many threads I've seen where ppl get the Supra/Audi TT setup only to find out that they need to get larger rims, not to mention expensive 17" low-profile tires to match which costs much more in the long run. Mine will work with 15" rims which is the strongest selling point IMO
As far as the performance aspect goes - I would love to pit both cars against each other sometime just to see! But it wouldn't be a fair comparison since I run a ~2700 lb 4-cylinder vs a ~3300 lb 1MZ-FE or equivalent. But I'd love to test it out provided everything works OK. Heck, we could even swap brakes and tires between cars and try it that way - just have to wait and see I guess!
