clutch pedal return spring broke. is it important ?
hey guys
there are two springs for the clutch. one spring is above the clutch pedal and its constantly pulling the clutch up.
the other spring is below the clutch pedal. it pushes up the clutch pedal when the pedal is above the halfway point and it pushes the clutch pedal down when its below the halfway point.
the top spring broke. is it important ? does it affect the feel of the clutch pedal by a lot ? im not sure if i should get it replaced. if it affects the pedal feel by a lot, then i'll definately get it replaced
thanks
