It can be done, but you will need to remove the wiring harness that goes from the head unit to the amp under the passenger seat, and also you will need the amplifier. It would be much easier just to get a double din unit that does not use an external amp. For example, look for faceplate# 16814, you commonly see this unit in the Sienna and Gen4 Camry, and some other Toyota models.
edit - part number is 86120-0C020
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
