Thank you for the info!
So I ended up bending a couple wrenches in half trying to get the control arms off the crossmember... I will have to go back with better equipment.
In the meantime, we put the car on the lift anyway because I'm having issues I didn't think were caused by the crossmember.
The rear driver's side wheel, there is play if I face the hubcap, grip on each side, and pivot about the axis of the strut (i.e. i can "twist" the wheel a little). My buddy said its the strut, since we already did the passenger side strut a few months ago because of a different issue (I know, I should have done both).
I'm not convinced though, because the entire strut moves with the tire. The point where the play stops is at the control arm bushings. the rod that goes parallel to the tire between the two bushes moves inside the bushes.
So to me, it's the control arms (more specifically, their bushings) that are bad.
Any thoughts?
