Scraping noise at startup? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2011, 07:09 AM   #1 (permalink)
View crazy_camry's Photo Gallery
I have a 98 camry IMZ-FE. I recently changed the starter motor and now there is a metallic scraping noise on startup. It is the pinion gear on the starter motor when it engages the flywheel. Why is this happening?
crazy_camry is offline   Reply With Quote
Old 04-30-2011, 07:29 AM   #2 (permalink)
TWO-VEE-ZED
TWO-VEE-ZED's Avatar
View TWO-VEE-ZED's Photo Gallery
Sounds like it`s either got worn teeth on the pinion or worse,on the flywheel or the starter motor isn`t engaging properly or starts spinning before engaging.First check the teeth on the starter and flywheel,then check the pinion solenoid/wiring.
TWO-VEE-ZED is offline   Reply With Quote
Old 05-01-2011, 11:13 AM   #3 (permalink)
I beleive this is the problem, the old starter i had didn't make the noise. What does this mean, that the solenoid is bad?
