after 2 days of unscrewing stuff and asking questions im hoping to do this thing in the morning.
i TOOK the bottom part of dash off to try to see where the ignition wiring harness is located pics are below.
I had a couple questions does the harness connector release out easily like other connectors?
I have 2 circles of what i think may be the ignition wiring harness circled in green and red. Which one is it? the12volt.com says the constant is the white. On one of the harnesses i see what looks like atleast 2 white wires in same harness.
do i need to strip some insulation to use the multimeter or can i reach metal in the connector?
ANY OTHER HELP welcomed
