If the water pump has been pin pointed as the cause of leaking; you're going to need that entire timing belt kit because the water pump is driven of the timing belt. Replace the tensioner, idler, spring, and the t-belt along with the water pump. The cam and crank seals are optional if it’s leaking, crack, or dry. The oil pump seals can be done now too. The kit with water pump varies anywhere from $70 to over $200. Shop around.
Also, replace the thermostat along with the radiator and refill the cooling system with 50/50 red Toyota coolant and distilled water.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
