a/c not working-no power,.. 10a fuse is good.. really need help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2011, 11:51 AM   #1 (permalink)
View garytho's Photo Gallery
My a/c seems to have no power. The light does not come on the switch when engaged. Checked the 10amp fuse in passenger side kick panel and it was good. I really need help here guys!!
I'm in between surgeries on my leg due to an accident at work and money is seriously tight right now.
I need some help figuring this out so I can fix it myself. Does anyone have any ideas where or what to check?? I searched the forums and cannot find anything.
PLEASE HELP!!!!
garytho is offline   Reply With Quote
Old 05-04-2011, 03:14 PM   #2 (permalink)
View 12340987's Photo Gallery
there is also a relay for the compressor. Depending on what year you have you might also be able to get into a diagnostics mode through the climate control module, I'm not too sure on a camry.
12340987 is offline   Reply With Quote
Old 05-04-2011, 05:06 PM   #3 (permalink)
Is this relay usually next to the fuse that controls the a/c in the passenger side kick panel??
I have a 96 Camry 2.2
Any help from members would be GREATLY appreciated!!!!!
Old 05-04-2011, 05:18 PM   #4 (permalink)
rusty9's Avatar
Gameroom cash: $440905
View rusty9's Photo Gallery
well, it wont come on if the system is not charged. whats the previous history? was it working fine and then just stopped?
rusty9 is offline   Reply With Quote
Old 05-04-2011, 06:10 PM   #5 (permalink)
I just bought the car last month with 104k. I honestly didn't check to see if it was working since it was so chilly at the time. The car was extremely well kept and the previous owner was more than upfront about what the car needed (rear brakes/gas filler tube) but nothing was mentioned about the a/c. So I'm assuming that it worked OK last season. The car truly is in fantastic shape so abuse was never a factor.
The compressor does not start when the switch is pressed. I'm hoping that someone has had this problem before and can share some insight into a repair.
My fingers are crossed!!!!!! Money is real tight since my accident and I'm hoping to fix this on my own with some help from my brother in law since I'm a bit disabled right now.
Old 05-04-2011, 07:59 PM   #6 (permalink)
rusty9's Avatar
well, like i said, the compressor is not going to come on if the pressure switch is telling the ac amp theres no pressure in the system. i suppose at the very least you can buy one of those cans of refrigerant with a gauge built in at the auto parts store to see if theres anything in the lines.
Old 05-05-2011, 10:44 AM   #7 (permalink)
I guess thats a good starting off point. Thank you.
Could you tell me where the relay is for the a/c if it is necessary?
Old 05-05-2011, 01:13 PM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Look at this : A/C light blinking
The a/c indicator was blinking to indicate no power to a/c clutch. It is usually in the engine compartment fuse block, look behind the battery for 4gen camrys. I tested with replacing relay with a known good relay.
The aluminum can in front of the rad has a sight glass, and an electrical connector that you can jump to see if the a/c clutch is bad or the relay.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
