Real slow oil leak on back of engine (can't determine source) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-04-2011, 06:17 PM   #1 (permalink)
View steppinthrax's Photo Gallery
I have a 99 4cyl toyota camry. It's got 70K on the odo. I recently did an oil change and drove 400 miles. When i went to filll up I notice the oil was below the L mark on the dipsitck. I put in a quart and drove off. I checked it again and noticed it dropped a bit. I run the engine and can't see any oil physically dropping out of the engine. I lifted the car up and noticed the following areas.
1. No oil around oil pan
2. No oil around timming cover.
3. No oil around tranmission.
4. if I look up I see oil drops hanging for most of the intake manifold bolts.
So my only thinking is if the intake manifold gasket is bad can oil leak from the engine!!!!!
steppinthrax is offline   Reply With Quote
Old 05-04-2011, 06:43 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I would suspect the valve cover gasket. try retightening the bolts and see if that stops the drip.
The Jedi Speeder at CarDomain
