Check engine after some service P0441 & P0446 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2011, 02:16 AM   #1 (permalink)
View mnsweeps's Photo Gallery
I did all the work except the battery terminal cleaning mentioned in this thread.
This evening I am getting a check engine light on with P0441 & P0446. I am taking it back to these guys tomorrow.. do you guys know what could have been missed or messed? Thanks in advance.
mnsweeps is offline   Reply With Quote
Old 05-05-2011, 08:43 AM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
IIRC those are the EVAP failure codes. could be a loose or cracked gas tank cap (or bad gasket on cap), check it first.
The Following User Says Thank You to fenixus For This Useful Post:
mnsweeps (05-05-2011)
Old 05-05-2011, 01:14 PM   #3 (permalink)
Just came back from mechanic. He tightened(with a plastic tie) one of the black tubes running into the valve and that seems to have fixed it..
Old 05-05-2011, 02:05 PM   #4 (permalink)
Toy-rollin
View Blaam's Photo Gallery
lol he fixed the light probably but he may not have fixed the problem
Got Trophies?
Blaam is offline   Reply With Quote
Old 05-05-2011, 02:07 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
it's a temp fix
if line was cracked then it needs to be replaced. possibly he also reset the codes, so it may come back on its own in a few days.
Old 05-05-2011, 02:47 PM   #6 (permalink)
Originally Posted by fenixus View Post
it's a temp fix
The line is new and was replaced by him last friday..I saw it myself when I was there..
Old 05-05-2011, 03:01 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
ah, then he must have used SAE vacuum line and not an OE metric replacement. probably the new line's inner diameter is larger than original, that's why the hose is loose and was causing the vacuum leak in first place.
Old 05-05-2011, 08:17 PM   #8 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
^ +1
time to order some metric lines on eBay I guess.
