DIY Subs/Amp install 99 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2011, 05:52 PM   #1 (permalink)
View tjmappe's Photo Gallery
Hi there forum!
I'm working on an amp and sub install in my 99 Camry LE. This is my first time doing this particular install, but I've replaced the speakers and stock receiver with aftermarket stuff so I have some experience with wiring etc.
My question is, if I want to wire the turn-on lead for my amp to the cigarette lighter, which wire do I crimp it to? There are four wires. Pink w/ blue stripe, white w/ black stripe, green, and black. I need to know which of these is hot when the ignition is on.
Thanks,
tjmappe
tjmappe is offline   Reply With Quote
Old 05-05-2011, 05:55 PM   #2 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Why not just tap into the remote wire of the radio...?
Chris Crash is online now   Reply With Quote
Old 05-05-2011, 05:59 PM   #3 (permalink)
Do you know which wire is the remote turn-on for the receiver?
Old 05-05-2011, 06:04 PM   #4 (permalink)
Well you've replaced the headunit with an aftermarket one, so there SHOULD be a remote wire incorporated in the harness. They're usually blue, and labeled. If not, you can always tap into the yellow wire (I think...)
Old 05-05-2011, 06:15 PM   #5 (permalink)
I didn't have a harness for my aftermarket receiver so I cut off the factory harness and crimped each individual wire to it's corresponding one on the receiver. Do you know what color the wire for the remote turn-on for the stock receiver was?
Old 05-05-2011, 06:25 PM   #6 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Why destroy the factory harness, adapter costs like 15 bucks.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 05-05-2011, 06:29 PM   #7 (permalink)
Yeah I know. I was 16 when I did it. Anyways, what's done is done. It would be really simple if I could find out what wire on the cigarette lighter is hot when the ignition is on. Those wires are more accessible and it would be easier to run the amp's remote turn-on wire from there too.
Old 05-05-2011, 06:47 PM   #8 (permalink)
Haters Gon Hate ;]
gr91's Avatar
Gameroom cash: $130750
View gr91's Photo Gallery
You shouldn't tap it into the cigarette lighter cause the load on the wire is just for the cigarette lighter. Best thing to do is to t-tap it into the blue wire coming from the back of the radio! That's the ONLY place you should put it on! Anywhere else is just asking for blown fuses!
-1991 Corolla Dx - gone :/
-1992 Toyota Camry LE- Restoration Project-FAILED!
-2008 Honda Civic ex Coupe!
gr91 is offline   Reply With Quote
Old 05-05-2011, 07:03 PM   #9 (permalink)
Ok, so the blue wire that is coming from the back of my receiver that is labeled AMP REM MAX 0.3A (I'm assuming this is the remote turn-on wire.) is not connected to anything. Somehow my receiver still turns on and works fine. I'm not sure what I did, but I'm just looking for a safe place to crimp my remote turn-on for my amp.
Old 05-05-2011, 07:08 PM   #10 (permalink)
Avy
Take a picture if possible.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-05-2011, 07:23 PM   #11 (permalink)
Pics
http://www.flickr.com/photos/6253830...n/photostream/
Old 05-05-2011, 07:24 PM   #12 (permalink)
Haters Gon Hate ;]
gr91's Avatar
Yes that one! That's to turn on the amplifier when the radio turns on! If you don't have an amplifier the blue wire doesn't need to be connected to anything! That is the safest and best place! Make sure to use butt connectors and wrap it in electric tape so it doesn't ground cause that's a positive wire! I KNOW this will work as I've installed countless radios stock AND aftermarket of Most brands!
Old 05-05-2011, 07:27 PM   #13 (permalink)
OHHHHHH.
Ok, just realized my mistake. Sorry for my incompetence, and thanks for your help!
Old 05-05-2011, 07:39 PM   #14 (permalink)
Haters Gon Hate ;]
gr91's Avatar
OHHHHHH.
Lol don't worry about it dude! It happens to the best of us! But now you know! No problem thts what we're here for!
The Following User Says Thank You to gr91 For This Useful Post:
tjmappe (05-05-2011)
