96 1MZ-FE - Rear bearings does it matter for ABS/non-ABS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2011, 08:24 PM   #1 (permalink)
Gameroom cash: $148300
View SilverSoarer's Photo Gallery
http://www.rockauto.com/catalog/x,ca...FE%255D%2BDOHC
SKF shows bearing for non-ABS and ABS are same unit.
Timken shows non-ABS unit bearing only.
Beck-Arnley does not specify whether ABS or not.
Why the discrepency ?
SilverSoarer is offline   Reply With Quote
Old 05-05-2011, 08:36 PM   #2 (permalink)
OK I found out there is a slight difference.
Old 05-05-2011, 08:44 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Some manufacturers build all of them with the ABS tone rings. if this is the case you can use them on Non-ABS cars too. However, in case they build a cheaper non-ABS bearings then you can't use them on ABS-equipped cars.
This is the ABS/Non-ABS part I pulled from the Timken catalog, HA590370:
http://www.rockauto.com/catalog/moreinfo.php?pk=1118338
The Non-ABS part is HA590371. Note the lack of the tone ring disc:
http://www.rockauto.com/catalog/moreinfo.php?pk=1117113
Old 05-05-2011, 09:16 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
yes it does. hubs are slightly different.
